Old 11-10-2011, 02:03 PM   #1 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Frequency divider for VSS
I have a question for the electronics experts. My Honda's alternator has two charging modes. A high-output mode of 14.5 volts and a low-output mode of 12.5 volts for better MPG. The ECU selects one of these two modes based on a few different inputs. One of these is vehicle speed. The alternator is always in high-output mode over 40 MPH. My speedometer and odometer are cable-driven, the VSS in the speedometer is only for the ECU. So what I want to do is cut the frequency of the VSS in half to get the low-output mode at speeds up to 80 MPH. Even 60 MPH would be fine. I know this can be done with a 555 timer in monostable mode as shown in this link. What I don't know are the values for the resistors and capacitors in the circuit. I guess the VSS signal is 8200 counts per mile, based on the MPGuino Wiki page. It's a reed switch that grounds itself four times per cable revolution. I just want to space those ground pulses apart a little more. Any advice on what component values to start with would be great.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
