Old 11-10-2011, 01:41 PM   #29 (permalink)
roosterk0031
Your heater is thermostatically controlled, do you know the on/off temps? If the relatively low mass of the oil & pan heat up, maybe it's cycling and will never heat the coolant any more than that +10-15 degrees your test showed.
If you can get the same heater stuck to the block it might stay on longer and might show a bigger change.
