Old 11-10-2011, 04:19 PM   #30 (permalink)
Rick Rae
Rick Rae's Avatar
The CARDIS - '07 Nissan Versa S HB
90 day: 30.9 mpg (US)
Originally Posted by roosterk0031 View Post
Your heater is thermostatically controlled, do you know the on/off temps?
The setpoint is 238F.
If the relatively low mass of the oil & pan heat up, maybe it's cycling and will never heat the coolant any more than that +10-15 degrees your test showed.
Exactly. And there's the thermal loss from the block to ambient to consider as well.
If you can get the same heater stuck to the block it might stay on longer and might show a bigger change.
Aluminum block.
Not to mention it being a tiny, tightly packed engine with not much in the way of large flat unallocated surfaces. I think an actual block or coolant heater will be the way to go for that (for the CARDIS, at least).
Cheers,
Rick
