Originally Posted by Gasoline Fumes
Now that I read that again, that's what I initially wanted. I just assumed dididing by 2 would be easier. I just really want to trick the ECU into thinking I never exceed 65 km/h or 40.3 MPH. Does that change your recommended values?
Yes, it does. R1 become 3.3K ohm, and C1 becomes 3.3uf. Your car's engine computer would never see any speeds above about 40.31 MPH.
As far as simply disconnecting the VSS wire, I imagine it would throw a code.
