Old 11-10-2011, 08:56 PM   #122 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Originally Posted by alohaspirit View Post
nice!
what did you have in mind for the mechanism?
It will be controlled by two door-lock actuators. They will act as a pulling horizontal actuation on each side of the floor register. Only one actuator will be active at a time and pull a bicycle brake cable in order to OPEN or CLOSE the grille opening.
There will also be a small indication panel beside my scangauge. It will display when the active grille is either open or closed and warn me when the radiator fan is on.
