Old 11-11-2011, 01:49 PM   #3 (permalink)
Daox
You should be able to make a circuit using a voltage comparator like an LM211 or LM311 to do what you want.
For reference, you can look up autospeed's closed loop monitor circuit. I believe they use a similar circuit to power that. It would work essentially the same.
The Following User Says Thank You to Daox For This Useful Post:
SentraSE-R (11-12-2011)
