Old 11-11-2011, 04:09 PM   #51 (permalink)
Arragonis
The PRC.
Originally Posted by tinduck View Post
Obviously, you have never driven this kind of engine in a heavy car.
Obviously you have never driven a mapped one
A 1.9 old style 130PD TDI with a remap is good for 160hp at least, and over 250 lb/ft of torque. Do this from a PD160 engine and you could see 180-200 hp without changing anything else - add in a bigger turbo and intercooler and maybe 250hp would be yours.
All of this is irrelevant of course because even a 130 TDI makes 250 lb/ft of torque and you drive that, not HP. A remap puts you at 275, and with some good bits you could see north of 300-320.
At that level your 1.9 4 cyl TDI is making as much torque as a "modern" US V8 with far lower fuel consumption.
So its viable I think - it just needs to be built.
And if that doesn't work then there is always the 2.5 or 3.0 TDI V6s (although the 2.5 seems fragile...)
