Thanks, Daox. I should be able to use the closed loop monitoring circuit by having it monitor the TPS voltage, using the LED light signal as a triggering circuit to a relay to open the AC compressor circuit.
8307c4, I understand from your post I shouldn't shut the compressor alone. If I simply open the AC on/off switch with the relay, that should avoid your concerns, correct?
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
