Old 11-12-2011, 09:39 AM   #15 (permalink)
ncwa
www.howtobuildahybrid.com
ncwa's Avatar
Thanks for all great feedback. I am going to try to find a burette for my idle / regen / vacuum adjustments that I can do while parked in my driveway. Depending on the final setup, I may or may not use it for actual trips. I’ll post a pic if I get it working.
I also like the ideal of calibrating my fuel gauge by adding small increments of gas and measuring the sending unit’s resistance.
Has anyone tried mounting only the bottom of a burette to the fuel line to use it as a visual fuel gauge (like you might see on older water tanks)? Although MetroMPG’s method sure seems safer – and thank you Old Mechanic for the tip to this method.
Slowmover – it is a 66 Mustang with a straight 6 (200ci) engine and a brushless DC electric motor.
Thanks again everyone!
NCWA
