Originally Posted by Ryland
It's a pretty solid little engine on there, keeping clean gas in it will go a long way, I'm not sure about the smaller honda engines like you have, but on the larger ones they have an oil spinner that is a little spinning cup that separates the metal from the oil, they are often under one of the two round covers on the engine, right side is most common, if you don't have one then doing an oil flush might be a good idea to get the 30 years of sludge build up out...
I'm just curious, how would you suggest doing an oil flush? I've never really figured out a good way other than just changing the oil, running it for a few small tasks then changing it again. Basically two back to back oil changes with a small amount of use in between... Is there another better way?
"May the wind always be at your back and the sun always upon your face. May the wings of destiny carry you aloft to dance with the stars."
~ Boston George
