Originally Posted by Gerrelt
Where did you get this version of that image? It's the same as the picture I got (see: picture). But yours looks like the original non-photo shopped version. Seeing the line in the middle of your picture, is it a scan from a book?
(btw, I can see smoke attached to the rear window in your version...![Stick Out Tongue](/forum/images/smilies/tongue.gif) )
Gerrelt,if you can find the thread FLOW-IMAGES ,there are some more wind tunnel smoke flow photos.I think there are two images of the Golf/Rabbit,with smoke being injected into the airstream before,and directly into the wake.
I think what you're seeing is some of the smoke caught in the wake circulating up under the outer flow field.
The two images are in Hucho's, Aerodynamics of Road Vehicles.
