Old 11-12-2011, 04:45 PM   #8 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Yep, use a decent motor oil with a bit of Sea Foam or other crank case additive, then drain it right away while it's good and hot, but what works better is just pulling the side covers off the crank case and scrubbing the sludge out of the bottom of the crank case, then you know what you started with and what it looks like inside when you are done.
