Old 11-12-2011, 10:36 PM   #12 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 48.08 mpg (US)
Originally Posted by Demonic_Bloodfeind View Post
LIST OF IDEAS SO FAR: (WAITING ON FUNDS)
1) a/c-DELETE
2) air damn- REPLACE
3) f/p fender- REPLACE
4) thermostatic air cleaner valve + air heater line- FIX/ REPLACE
5) O2 sender- REPLACE
6) catalytic converter- DELETE
7) strait pipe- install
8) clean under body of truck
9) plexi glass over bucket style lights
10) smooth hub caps
11) seal and smooth gap between cab and bed W/ rubber/plexy glass or duct tape
12) move thinner tires to front when i get new A/T for rear
13) strip and repaint truck then wax
14) under drive pulley
15) electric fan DELETE manual fan
16) replace gaskets for timing chain cover/ oil pan/ transmission oil pan
some of those are more maint. than for getting better mpg but im useing this list to keep track of stuff i need to do to
ANY OTHER LOW COST MID-RANGE COST IDEAS OUT THERE??
For gas mileage, yes on 1, 2, 4, 5, 8, 10, 15. Also a grille block. An underdrive pulley will hurt cooling if you drive at low RPM. Number 6 is not consistent with ECOmodder, and it won't help your mileage.
