Old 11-13-2011, 09:40 AM   #21 (permalink)
user removed
Originally Posted by villain.ind View Post
"thanked," that solves my problem completely!
the problem with plumbing the vapor directly into the engine is that it is isnt metered. the engine would run rich. unless it isnt enough to make a difference, in which would make this mod useless.
The modern feed back systems would prevent rich operation as long as the additional fuel supplied did not exceed the available oxygen. Not sure about a potential Check Engine Light situation if the system detected something it could not handle, but the O2 sensor is the final control of overall mixture control. Running rich would require a non functional O2 sensor (already a CEL) or the fuel management systems lack of compensational range to reduce the gasoline delivery to compensate for the volume of alternative fuel delivered.
Can you say Natural Gas-Gasoline powered car?
Some Propane or Natural Gas added to the system should work, as long as it is done properly.
regards
Mech
