Originally Posted by Old Mechanic
As far as a home brewed Direct Injection system, that's a serious stretch, since most DI systems have engines using higher compression to utilize the advantages of DI as far as the direct cooling of the combustion chamber by the fuel injected directly into the combustion chamber itself.
While true, the art or modifying CR isn't exactly in need of new research.
