Old 11-13-2011, 11:25 AM   #37 (permalink)
puddleglum
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
IMO, the tank style heater is the best choice. It uses more power, but it also heats quicker and hotter than other types, so you don't need it on as long. I think the cost/degree temp. rise would be about the same, maybe less. I read on another thread that a member with a Prius can bring his car to full operating temp with a 1000watt tank heater in about an hour. The catch is you need to plumb it into a block drain for it to be most efficient. Using the heater hoses may work on some vehicles, but not well at all on others. That's why I don't have one, I have no block drain on my car.
Overall efficiency will depend on your setup and energy cost in your local area. I did some quick testing last spring (need to do more maybe) , but, it seemed to me that there was no visible overall cost savings in plugging my car in above around 40-50F. That was just my car, though, others may have better results. Also, I have no way to quantify the cost of wear caused by short tripping a cold engine.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
