Old 11-14-2011, 01:39 PM   #21 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Demonic_Bloodfeind View Post
ANY OTHER LOW COST MID-RANGE COST IDEAS OUT THERE??
Driving slower will negate some of the bad aerodynamics.
Add in a grille block, and reduce the amount of air going into the engine compartment.
Obviously, keep an eye on coolant temperature when you first do this mod.
155F coolant temp seems very low. Is your thermostat OK ?
All vehicles I've ever driven, had the temp needle in the mid-position as the normal position.
