Ok I know the temp is low and it is due to a cooler thermostat so thats a good idea
Unfortunately I cannot reduce weight I'm going to have to put more in as l have more equipment to haul starting DEC.
Truck is driven every where from mountain back roads to hours on the freeway all the time so hard to set where I drive the most.
Ive thought about doing the tranny swap with the r700 but not sure how much power I would lose rear gears are also an option.
Something I've been thinking about was plexi from front of steel bumper to top of grill with a few holes drilled into it or a slat to eliminate the box front end aerodynamics but keep some air flow to the radiator and air intake.
Btw I am not going to put a diesel in it EVER just saying.
Ive begun to drive a little slower and neutral coast down hills when I can ill give y'all an update on that stuff Friday but don't expect to much I've been driven pretty slow before to and coasting when I could in drive.
wow didn't notice all the mistakes on my tablet lol fixed now
