Originally Posted by gralewicz
Thanks, I wasn't sure if you had added/removed anything from the data sheet design.
Are you keeping the clamping diodes from the MOSFETs or using something else with the IGBT?
What are you doing with the fault output?
No clamping diodes from the Mosfets are being used and the IGBT board/circuit contains all necessary parts to drive both VLA500-01.
Faults are being detected in the controllers software as per Paul's design.
