Old 11-14-2011, 07:13 PM   #2 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Correction. It uses heat to create the mechanical motion to pump the heat.
Edit: Let me elaborate. Some of the energy goes to move the pistons and gasses around. The heat pumping is largely done by fluctuating gas pressures in the different areas.
