Old 05-19-2008, 08:48 PM   #27 (permalink)
ebacherville
Veggiedynamics
Volt12 - '12 Chevy Volt base
Well as for worring about curbs etc, well it s not to bad.. i was able to gtet it up on Ramps...
Here are some photos of it up on ramps, I was coating the inside with a laer of resin and bracing everything under there..
You can get a good idea of the profile of the nose.. leaves plenty of clearance, i was very suprise i could get ramps under there, its a tight fit but worked fine.
Once i get the entire thing coated with resin inside and out ill start filling the voids with foam and smoothing it out a bit.
