Old 11-16-2011, 05:48 PM   #6 (permalink)
aerohead
28-degrees
Originally Posted by bdubnelson View Post
yeah right now I'm at 28deg slope. I was hoping to keep it close to 19-20deg. I was thinking about adding a window but wanted to keep it cheap right now. I only spent about $60 on the cap supplies. The wife doesn't want to drive it cause she cant see out the back... maybe I won't ad a window after all? LOL
Like what you've done,and big thumbs-up!
I did want to mention(since you mentioned it),that 28-degrees is an angle Hucho warned us to steer away from like scurvy.
Evidently,at this angle,the separation line will dance back and forth,with a squareback wake one instant,then a fastback wake another.The whip-sawing wake ends up like 'flutter' in aircraft,which can hammer things to pieces.
The wake is intense turbulence with very high drag.
If you must do a simple 'angle' try and do no more than 15-degrees.
Curves are best,but as you now know,more difficult to execute.
