Old 11-16-2011, 07:22 PM   #16 (permalink)
user removed
Originally Posted by Ryland View Post
Another reason that I see for having just a copper coil in the heat storage tank is that thermal expansion of the coolant is going to over fill your over flow bottle next to the radiator if you have 10 litters/2.6 gallons more fluid in a system that is designed for around 3 litters total.
Larger bottle or just lower cold coolant level. As long as the hose is not above the coolant level you have no problem.
regards
Mech
