Thanks for your post.
Originally Posted by aerohead
Guillermo,I've located some figures for your truck,but need to dig a little longer.I think I can pull them together by this coming Saturday.
*You might tell us about your driving conditions there in Lima.If you do a significant portion of steady high-speed highway driving the aero mods should really help you.
I drive the truck only on highway and off road ways because i have a car for the city. I use the truck only for travels.
*Also,it would be good to know about the Blazers gearing,and the kind of engine RPMs she turns at highway speed.
I do not know how are the gearings set.
The average RPM on highway is 3000
*I presume you have a thermo-clutch on the engines cooling fan?
Yes i have one
*Is the original fan shroud still in place?
I have not the original, but i ordered making a new one.
*How often do you use the 4-wheel-drive?
Not very often.
*Could you do with narrower tires?
I think it was not necesary buy the 31" tires. But I did. I could put some narrowers on.
*Could you get by with less ground clearance?
Maybe 1 or 2 inches less
