At the rate of gaining 4/10ths of a mile for every ten miles your odometer will be off 4,000 miles per 100,000 miles. Your car has less mileage on it then you thought and your mpg is not quite as good as you thought, you should be subtracting 00.4 off of your trip meter before calculating its fuel economy.Assuming the mile marker signs are correct..
Save gas
