Old 11-18-2011, 04:03 PM   #6 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
I believe that when lowering your car, you have to invest in a good set of shocks and springs. Changing only the oem springs will not provide an optimal compromise between comfort and handling. I will most likely reduce the tire pressure from 40 psi to 35 psi once the suspension upgrade will be done.
I intend to keep my car for another 5+ years, so the investment is justified in my case.
