Old 11-18-2011, 08:05 PM   #69 (permalink)
Duffman
Yeah but if you made torque curves at 75%, 50% and 25% throttles the shapes would be similar to WOT, Obviously though less throttle would taper off faster at high RPM.
Talking about BSFC curves becomes pointless at low throttle openings, if your throttle is nearly closed then you are geared wrong and barking up the wrong tree to begin with.
