Originally Posted by CigaR007
I will most likely reduce the tire pressure from 40 psi to 35 psi once the suspension upgrade will be done.
You'll probably find that you'll lose more MPG from this than you could possibly gain by lowering the car.
I put about 60,000 miles over the course of about 8 years on a set of coil-overs and aftermarket shocks on my CRX. Tokico Illumina shocks and Ground Control coil-overs, adjusted for a slight drop--on the order of 1.5". No problems from them, good stance and good handling.
-soD
