Old 11-19-2011, 07:34 PM   #30 (permalink)
Cd
Ultimate Fail
Cd's Avatar
It would certainly be interesting to see a tuft test along the sides of those fenders Frank.
Thanks for posting the example.
I can certainly see what Aerohead was referring to about immediate reattachment along the sides.
As far as the little tabs that hold the side signal lights on, they might even function the same way that the creased sides do on the front end of the Prius.
Its hard to tell without tufting it though.
( I hope you do get around to fixing that front end ! Good luck passing inspection without the turn signal lights )
