Originally Posted by Sven7
rainagain, if you make one more post you should be able to go back and edit in the photos
Anyway Perhaps you thread a carriage bolt in there to hold it in place?
Thanks for the replies, that's the right Fife! (I had to delete the link, with the less than five post thing again) I was thinking about screwing the tray to the arch liner but the liner's only held in with those plastic rivets and I don't think it'll be strong enough to pull the tray up. The idea of the foam sounds good but I think I'll need to cover the arch liner in cling film first to stop the two sticking together as I need to be able to remove the tray to change the oil, etc.
From reading about tyre spats the angle of the tray should help cut down on tyre drag if I leave it at it's current angle.
