Thread: used radiator ?
Old 11-21-2011, 11:46 PM   #3 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z Base
90 day: 44.08 mpg (US)
normal wear
You should see my echo's radiator !
The upper part is fairly "clean". The bottom section is plugged and that is where all the incoming air cools the radiator. With my partial lower grille block, the cooling is working as it should, but I do have a feeling that it would be more efficient if the fins were in good shape.
If you want my opinion, keep your original radiator and save your money.
