Old 11-22-2011, 10:55 PM   #3 (permalink)
hondaguy72
Enthusiast
It will work just fine. You won't be able to set up a lean burn mode, so basically you can run the car in vtec just about all the time. I'd just run the dpfi setup and use the vafc to open the solenoid about 1800-2000 rpms. The high swirl mode will help the car idle smoother. (when vtec not engaged)
