Old 11-23-2011, 09:24 AM   #18 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by slowmover View Post
I like your explanation of how it might work, hadn't thought of that..
I'm only guessing it's based on speed and coolant temp. Speed because I can see it goes up when I'm at higher rpms, and also because that would phisically make sense--the oil pump is tied to the crank so more rpms mean more oil flow. I'm guessing it's alos based on coolant temp because I definitely can see that the oil pressure "gauge" reads lower when I pre-warm.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
