That sounds reasonable. Most of what I know about these modifications is done for performance purposes; I guess the fine line is where performance, efficiency, and economy meet. Under low loads, these modifications (timing and AFR) probably shouldn't cause much damage.
You're absolutely right, though... None of this can be established without logging and tracking the modifications and data.
