Old 05-20-2008, 09:07 AM   #33 (permalink)
JoJotheTireMan
Originally Posted by roflwaffle View Post
It depends on what your trans code is but if you have a 3.67 R&P you're about as low as you can go stock. IMO your best bet for gearing experiments is to get a couple significantly taller tires on steelies from the j-yard with a scanguage or open equivalent (*plugs the instrumentation forum*) and do a few runs at 55mph over the same route switching tires between each to see if taller gearing will help you out much.
Yes, 3.67 R&P sounds right, just do not have the book with me, but I do know it's what they put in almost all of the A3 cars, in other words I do not have the shorter geared GTI gearbox or anything. Indeed, I could try a little taller tire, but wheel well clearance will limit me from going much taller than stock. Due to my typical commute being mostly highway, I think I have exhausted my gearing options with the .715:1 TDI 5th gear, should do the trick, now if I can find the time this weekend to get the gearset swapped I'll be in better shape soon. JoJo
