Old 11-25-2011, 06:03 AM   #3 (permalink)
F8L
F8L's Avatar
F8L's 2012 Prius - '12 Toyota Prius Three with Solar Roof
90 day: 62.14 mpg (US)
As we allow know, the larger diameter tire will reduce rpm at cruising speed. Weight differ should be negligible. I would make sure you stay at the same width so you don't increase friction, get a LRR tire like the Ecopia EP100/Ep422, Energy Saver A/S, dB Super E-Spec or Nokian i3, etc. and ensure you register the speedometer difference so you don't mistake a mpg due to traveling slower/faster than you think you are.
2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Prius Plug-In 15" Wheels | Michelin Energy Saver A/S 195/65/15 tires | TRD Lowering Springs | WeatherTech FloorLiners | Scangauge II | Morimoto/DDM HIDs 5000K | Clazzio Leather Seat Covers | Best Tank: 71.7mpg@702miles | Best Trip: 95.9mpg@233miles
