I put 20k miles in my fuel log, assuming my OEM tires and odometer were accurate. Then I bought taller tires. In the course of testing them, I calibrated them during a long drive to Southern CA. The odometer readings with the new tires were 9.9% pessimistic. 100 miles on the odometer was actually 109.9 miles traveled. I checked this over 20, 60, and 80 mile distances.
When I got back from that trip, I checked my OEM tires, and found the odometer was also pessimistic with them: 100 miles on the odometer was 103 miles traveled. Yes, I went back and redid my mileage log(s).
Both UG & SG lose miles during the key off/ECU reboot entering EOC. If I drive my 10 mile test loop with cruise control, and then do the same drive with EOC P&G, I'll see a .3 to .4 mile shorter trip distance with UG or SG doing EOC with the key. If I do it with a kill button, the trip distance is the same as with cruise control.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
