I couldn't remember what it was either, so I searched the EV Tech archive.
So this is Quoting Otmar from the EV Tech list Dec 15, 2009 so the pricing is probably higher now:
"I use this in the Zilla:
From McMaster:
Dow Corning 748 Noncorrosive Silicone Sealant 10.1 Ounce Cartridge, Off-White
In stock at $15.34 Each
748 Noncorrosive Nonflowable Low Odor- Use with
corrosion-sensitive electrical and electronic equipment. Plus, it
doesn't have the harsh vinegar smell of other silicone. Bonds metal,
plastic, glass, and rigid PVC. Resists moisture and weather. Begins
to harden in 30 minutes. Complies with FDA CFR21 177.2600 covering
indirect food contact. UL 94HB listed.
-Otmar-"
It seems to be the same thing used in many power supplies etc to stabilize the components.
