Old 11-27-2011, 09:57 AM   #13 (permalink)
nemo
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
It might be possible to use two exhaust cut out valves to remove the flow from the heat exchanger. Basically you would have two paths, one would be through the exchanger section. The reason for using two would be to completely isolate the the exchanger section. After the second valve it would flow through the normal exhaust system.
