Old 11-27-2011, 12:58 PM   #22 (permalink)
nathanabbott
Thanks. Arc. I'm building it in stages. The 914 trans. is rated for the torque, but you're right; the ratios need to be taller. So far, i've found a few folks that can regear it. Haven't done much digging through the racing supply atores yet, but taller gears are probably available, off the shelf. Hopefully. Wish me luck ;-)
