Originally Posted by Frank Lee
I'd take the whole exchanger out of the exhaust stream after it has warmed up; no restriction, and that's gotta be an awful tough life for an exchanger that is continuously exposed.
EGR coolers take that abuse all the time. Actually it's even worse on most diesels the EGR see pre-turbine temperatures which can be a few hundred degrees hotter than post-turbo temps, where I want to put it.
My thinking was to get a really big EGR cooler (like out of Class 8 truck or something). If it's large enough it actually wont cause much more exhaust restriction than a normal exhasut pipe. EGR coolers are also already designed with the goal of having minimal restriction. If I can't get an EGR cooler I could always just expand my exhaust pipe (say 4" up to 5") and then put a copper coil in it. That probably woudn't increase backpressure because the flow area increas (from 4" to 5") would make up for the flow area decrease from the coil.
