Old 11-27-2011, 05:47 PM   #21 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Diesel_Dave View Post
I can’t think of any downside to this.
Excess heat being pumped into the coolant ?
In order to work & warm up quickly, it needs to be close to the engine.
Thus it'll get pretty hot in a short while once the engine gets up to normal temperature.
Leaving the heat exchanger open on one end will boil the coolant in the heat exchanger, which then will go into the system to be replaced with colder coolant, repeating the cycle.
So you need to shut off the flow of coolant, but you can't close both ends or you'd have pressure building up - though you could possibly vent this into the radiator overflow (which might need more volume).
Putting it further back in the system will reduce its effectiveness to warm up a cold engine, as you need to wait for the exhaust system to warm up.
Another way is 2 exhaust paths - one over the coolant heat exchanger, one bypassing it.
That sort of system would need some critical pipe-work to make sure no hot exhaust gasses go over the HE when not needed.
