Old 11-27-2011, 05:30 PM   #53 (permalink)
wizardman42
steam injection
I have been tinkering with this for 2 years now ,route a water line around the exhaust to heat the water , induct it in the air cleaner asmbl. between the filter and throtel plate , had a nissan up to 80 MPG. now the why. to break any molecule down you need to stress it , heat is a start , at 400 degrees F some water will break down , then put it into the combustion chamber and beat the crap out of it with the piston , then shock it with high voltage electricity , then subject it to more heat , then expose it to a good catalyst. yes hot burning carbon fuel and steam = a catalytic response , not ALL the water breaks down but a lot of it does . WOW!!! smokey unick had a Fereio up to 55 miles to the gallon useing a method called hot plasma injection . The biggest problem I have encountered is metering the water , too much puts the fire out, it can perk while the engine is off, ect.. I think cool mist .com is going to finaly get my money so I can meter the water through the heat exchanger , up to know I have spent maybe a wopping $50 on 4 different vehicals and have lots of great results including cleaning out a 6.9 diesel , that now runs like a sports car . ohh secret put a little dish detergent into the water , helps reduce the surface tension of the water , have good clean fun now !!!
