Old 11-27-2011, 06:24 PM   #17 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Sularus View Post
The power steering is electric assisted.
Good, so it doesn't drain power when you're not using the assist
If I save up and use the Nismo suspension it will not void my warranty and actually carries its own warranty. it is expensive though ($600)
As such it won't ever pay for itself.
It's an option if you need to swap the suspension bits later on when they're worn out though.
