Old 11-28-2011, 07:12 PM   #34 (permalink)
some_other_dave
The MAP sensor should not be able to affect the inside of the distributor. It sounds like you may have some kind of bad contact in your ignition system? Double- and triple-check the plugs and wires, cap and rotor.
If the stuff you saw in the cap was reddish-colored, I would tell you to get a new distributor. The "red dust of death" is a known failure mode for those...
-soD
The Following 2 Users Say Thank You to some_other_dave For This Useful Post:
California98Civic (02-09-2012), Cd (12-07-2011)
