Old 11-28-2011, 06:27 PM   #26 (permalink)
user removed
Originally Posted by 66sprint6 View Post
The tires are bigger making the odometer .054 off, but the trip meter is off by even more at .1 off. Grill block is def. on the list but I need to replace the thermostat and housing first as it barely even comes close to warming up even in 60* weather.
Matt
The thermostat should help significantly. Pirce original equipment before you just go get aftermarket. Sometimes the OE stats work much better, faster warmups. Gauge should read just below the halfway mark when it is warm.
regards
Mech
