Old 11-28-2011, 11:53 PM   #5220 (permalink)
amino
EV DIYer
A puff of smoke....
Hi Paul,
I built the 500 amp controller from the kit last Month and after testing it a couple of weeks ago at 16 volts (2x8 volt batteries) with just the motor connected, all seemed well. I decided to install it in the car and test it at the pack voltage which is currently 80 volts, as I needed to test the precharge time, using a small 7 watt bulb through a solid state relay setup which I already had for the old Kelly controller.
When I switched the circuit on to activate the relay, the bulb did not light up. Instead there was a small puff of smoke from inside the controller, at the rear (M-) end , so I took it all apart and looked for the source of the smoke, but did not see any sign of damage anywhere! No burnt smell, no charred components.
I measured the Gate-to-Source resistance on all the Mosfets and they seem fine (infinity), although the one at the back (Q1) at first seemed shorted, but when I measured it again a little later, it also showed infinity between Gate and Source. Any suggestions while I have it apart?
Thanks,
Amin
Name:	Controller Wiring (1).jpg
