Old 11-29-2011, 10:33 AM   #35 (permalink)
honfit
James-
Several experienced techs confirmed that MAP sensors rarely go bad,but if
DTC P0108 recurs then consider replacement. Our dealership has only sold 2-3
this year for your civic ,if you don't count the returns from those that thought this would fix whatever was wrong with their car. Your replacement of tuneup parts was probably due anyway as part of routine maintenance every 30-60 k miles.As you probably know,one worn part puts stress on others in system and can cause them to fail.For example,worn or overgapped plugs WILL cause coil to seek path of least resistance and cause arcing inside distributor. I hope this helps and please keep us posted.
-Sean (Honfit)
The Following User Says Thank You to honfit For This Useful Post:
California98Civic (11-29-2011)
