The DC to DC converter is isolated from input to output, but I have no information on the isolation rating -- it's a Kelly 96V to 13.5V, and is switched into the circuit with th same solid state relay as the precharge bulb. The battery pack is not grounded with this setup --only connected to B- and DC/DC negative plus the heater 'negative' as shown in the diagram I attached previously.
