Old 11-30-2011, 01:03 AM   #5 (permalink)
sc2dave
Cam Analyzer v3.2 Test: 801-260 Folder: MY-TESTS Performance Trends (c) 2002 DELTA CAMSHAFT INC. 1-800-562-5500 DELTACAM.COM This Report Printed: 8:56 am 09-25-09 Page: 1
Cam #: 80 1-260 Operator: SCOTT
Report of: Cyl 1 , Cam CLine Dur Data Test Time: 12:21 pm 10/30/2007 Events Rated at .05" Tappet Lift Open Close Lb Area Lb Lift Vlv Lift RAR Lash LbSep/Adv Overlap
Int: 108.0 218.8 10.0 28.9 22.98 .285 .428 1.5 .006 108.4 16.7
Exh: 108.8 214.0 27.3 6 8 22.40 .286 .429 1.5 .008 .4 Advance
Lift Int Open Int Close Int Exh Open Exh Close Exh
BTDC ABDC Dur BBDC ATDC Dur
Cyl1
.003 66.9 72.2 319.1 78.6 60.7 319.3
.004 63.2 68.4 311.7 74.9 57.0 311.9
.006 56.2 61.4 297.6 68.0 49.1 297.1
.015 29.2 42.4 251.7 43.8 25.1 248.9
.020 23.9 38.8 242.7 38.5 20.5 238.9
.040 13.7 31.5 225.2 30.3 10.5 220.8
.050 10.0 28.9 218.8 27.3 6.7 214.0
.100 -6.7 16.8 190.1 13.6 -9.2 184.4
.150 -23.3 4.8 161.6 1.7 -25.9 155.8
.200 -42.2 -9.9 128.0 -10.6 -44.9 124.5
.250 -67.2 -30.5 82.3 -30.9 -69.2 79.9
.300
.350
.400
.450
.500
Test Setup
General Specs Int/Exh Specs
Type Measured with Electronics Intake Exhaust
Deg Steps: User Entered Rocker Arm Ratio 1.5 1.5
Lifter (profile) Type: Mild Solid Flat Actual Valve Lash, in .006 .008
For Cyl #: #1 Centerline, deg ATDC (mea'&MHD) 108.80
Degree Wheel Duration @ .050" (measurers. 84 na
Type: na Opening @ .050" (measured) 9.96 na
Closing @ .050" (measured) 28.88 na
Max Lobe Lift, in (measured). 2850 .2858
Gross Valve Lift, in (measured)
Designed Vlv Lash, in (measure^ na
Total Cam Advance (measured)
